MultiBooth Spraybooth Solution
Multibooth SprayboothFind Out moreOverspray is contained within the bays for a cleaner workshop environment -
MultiBooth SprayboothFully functional low bake spraybooth ovenFind Out more -
MultiBooth SprayboothAir handling plant for up to four cabinsFind Out more -
MultiBooth SprayboothPrepare, spray and bake your vehicle in situFind Out more -
MultiBooth SprayboothEasy glide sliding door, manoeuvrable by one operativeFind Out more
Prepare, spray and bake your vehicle without moving it using Junair Multibooth Spraybooth solution.
The Junair MultiBooth has been designed and developed to offer a flexible solution for those undertaking small to medium cosmetic repairs in a clean, controlled and safe environment.
This flexible spraybooth solution allows you to prepare, spray and fully bake a vehicle in the same cabin, eliminating vehicle movements. Each bay is designed as a combination preparation bay and full low-bake spraybooth, simply move the sliding door to the required cabin to convert it into a fully operational spraybooth.
- The MultiBooth takes advantage of a steel, double skin insulated construction which meets all HSE regulations and the required 30 minute fire evacuation time.
- The easy glide sliding door has been designed to allow one operative the ability to simply slide the door across the cabins. The door incorporates automatic interlocks to provide a safe, fully sealed and fully filtered environment.
- The MultiBooth spraybooth solution requires only one air handling unit which automatically activates the spray mode and adjusts the dampers to direct the heated, filtered airflow into the appropriate cabin once the sliding door has been locked in place.
- The cabins operate exactly as a conventional spraybooth once spray mode is activated. The heated air enters the cabin through a fully filtered input plenum and the rear filter chests provide excellent overspray mist clearance.
- Once the cabin is in bake mode, the air handling unit recirculates 90% of the airflow to deliver a full 80 deg C curing temperature.
- The cleanliness of the workshop environment is dramatically improved as paint overspray is contained within the cabins.
- The rear of the cabins can be specified with optional cupboards to store the materials and equipment required to prepare a vehicle. Mechanical and electrical services can also be integrated into the cabin including compressed air, dust extraction and electrical sockets, all with appropriate safety interlocks.
- Excellent visibility is provided through Junair's spraybooth lighting system.
Contact Junair Spraybooths for more information
For more information on MultiBooth Spray Booth Solution or any other Junair spray booth products, you can call a member of our friendly team on 01706 363 555 who will happily provide further information. Or alternatively leave your details on our contact us page and we’ll contact you as soon as possible.
